3 members (Otto Skorzeny, Gdads51, 1 invisible),
137
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,109 Posts1,056,266 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 98 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 98 | I`m trying to de-slop the shift lever. truck is a 49 2 ton GMC COE with a 4 sp muncie sm 420. To dissassemble the shifter,Ive been told to press and twist the lever counter clockwise and the lever should pull out but no had luck with that. Any other ideas will be welcome on how to take the lever out and what to do afterwards. The tranny is still in the truck not on the workbench and I`m not sure I can pull the top off to put it on the workbench. Anyone have a diagram of the actual top cover shifting lever mechanism? Many thanks, John Drabik | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You need to push down on the collar and then turn it counter clockwise. When you do that it should come off. Spray it with some penetrating oil and make sure you have it in neutral. | | | | | Joined: Jun 2009 Posts: 98 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 98 | Just did it! Thanks! A bit of PB softened up the old grease and off it came. Looks like the previous owner welded up the slop on the shifter end once before so I guess I can do it again also. Is there anything else in the shifter cover that may need to be adressed? | | | | | Joined: Jun 2009 Posts: 98 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 98 | Watta difference!!!!! Fattenned up the business end of the shift lever with some weld, made new pins and welded and milled new grooves in the fenobla. (The half ball socket) Almost too tight.
Thanks again Mr Stocker | | | | | Joined: Feb 2004 Posts: 29,804 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,804 | Now finish the job and treat the welds with Kasenit, and it won't wear out again, or at least not as fast. Welding up the wear spot and dressing the weld took all the surface hardening away so you've got nothing but soft, annealed steel left. Jerry
| | | | | Joined: Jun 2009 Posts: 98 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 98 | Good point. Ive heard of the product. Just have no clue how to use it. Will snoop the weld forum. Thanks. Good thought. | | | | | Joined: Feb 2004 Posts: 29,804 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,804 | I use it frequently in gunsmithing work. It's a coarse carbon powder that the part is dunked into after heating to a cherry-red color, then the heating continues until the surface of the metal absorbs some of the carbon. After a time, the red-hot metal is dunked into icewater, which results in a glass-hard outer surface with a tough, but somewhat flexible under layer. A little polishing of some slight surface roughness is required, but a hard, wear-resistant layer several thousandths of an inch remains after polishing. Jerry
| | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | You wouldn't happen to have any before and after pics of your job would you? I would like to do the sampe to my shifter.
Rick..... | | | | | Joined: Mar 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 66 | I am interested in how you did the repair,I have the same problem with my shifter, having some step by step pictures and a talk us through it would help a lot of folks.I have asked many people about this with no luck THANK YOU | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Excellent topic -- This would make a great tech tip if someone would take the pictures and send them to me ( [email protected])! Thanks, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I didn't know you could do this.
How do you know when they are too sloppy? Was the shift pattern real tight when new? Or did they wiggle some?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jan 2011 Posts: 90 New Guy | | New Guy Joined: Jan 2011 Posts: 90 | One quick Question does anyone know of a source for the new pins the shifter lever locks down on one of mine is seems too be very worn loose ?
1954 3600 With 1950's Powers of St Louis Utility Bed. My truck | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | Just an idea, I think those pins are stepped, and kinda like a rivet are upset on the end in the top casting. I have a transmission with loose pins to and have not yet attacked the problem. But I'm thinking they could be tightened by using a rivet gun, unless they are way too loose then a person may have to have some made or if you have a lathe make them.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Jan 2011 Posts: 90 New Guy | | New Guy Joined: Jan 2011 Posts: 90 | Thanks Truckrolet I figured they might be a build it yourself part, Will probably try what I did on a gear box back in the Uk Grind a Cap head screw too the size I need, then secure it with a nut from the outside not perfect but a solution. Plus one of my Dads old tricks from way back cut a piece of Inner tube so it fits Like a washer in the Retainer and it will stop it rattling
1954 3600 With 1950's Powers of St Louis Utility Bed. My truck | | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | What ever you end up doing, you need to make sure it stays tight. Any movement at all will let it keep wearing, if it ends up being a bolt, maybe some locktite.
