| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#71494 01/11/2007 6:19 AM | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | Thinking about a 454 in my '58. Anyone give me some idea of how difficult the swap is?? I have a 350 in it now. How is the clearance for the steering box?? What about exhaust headers...clearance?? Distributor clearance on firewall?? Any other issues I need to be alert to? Thanks in advance..
Carl
'58 3600 350/4-sp/stepside/big window cab '59 3100 235/4-sp/stepside
#71495 01/11/2007 6:44 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy cjoe, If I remember correctly the right head hits the firewall if you leave the bellhousing in the stock location, hope that helps. | | |
#71496 01/11/2007 7:18 AM | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | 3B "if you leave the bellhousing in the stock position" ?? Are you saying the big block motor has to be mounted left from the mounting position of the 350 (the location of the original 283) ?? If so, how much to the left??
#71497 01/11/2007 8:04 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 427 fits in pretty nice  lifts the front wheels too Bill | | |
#71498 01/11/2007 8:13 AM | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | cjoe, I think he is saying it must move forward as the head will hit the firewall on the right side of the vehicle. Check the clearence you have with the small block. Is it tight already? | | |
#71499 01/11/2007 8:28 AM | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | red58..is this yours?? Nice. 427 and 454 should be the same size, externally...right?? What tranny and what rear gearing???
Tomcoe....the heads both clear ok but my HEI distributor cap is REALLY close, not touching but very close.
#71500 01/11/2007 3:54 PM | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Years ago I put together a 55.2 with a big block. I used a stock truck bell housing. I don't recall the firewall interference, so it must not have been much. The headers were a bigger challenge. I am not sure which headers I used, probably Camero. The rear two tubes had to be removed and reworked. It is tight, but do able.
I used the stock small block front engine mounts. I do not think all big blocks are drilled for these mounts.
If you are going to use an auto trans, then none of this is relevent. You should side mount the engine and rear mount the trans, in doing so the engine can be located so that everything clears. | | |
#71501 01/11/2007 5:25 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | AFAIK all BB's are the same outside, cjoe - that one's not mine, good friends - I forget what 4 speed it has, but the rear is the stock 3.90  - hasn't blown it yet and he does abuse it sometimes - he found some Hedman's that fit ok the hei is too tight on any v8 in a TF - avette4me posted about the BFH method of gaining the 1/4" necessary, but doing a setup from scratch with the side mounts you can fudge it forward 1/2" or more Bill | | |
#71502 01/11/2007 6:43 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The only bbc that has a different dimension is the tall deck big truck engines (366/427) and the performance variants of them. I suppose you could also get in some clearance issues with tall rocker covers, too. You could always go Gasser style and use fenderwell headers from Speedway. Oh, and I've been meaning to post this, I found this site that has conversion axles for the '55-'62 diff. They convert to a 30 spline and later 12 bolt side gears. I had heard that the parts swap, but wasn't sure on the axles themselves. Something to keep in mind, you know. http://www.tomsdifferentials.com/catalog.asp?pg=14
Bill Burmeister | | |
#71503 01/20/2007 1:10 AM | Joined: Jul 2002 Posts: 18 Junior Member | | Junior Member Joined: Jul 2002 Posts: 18 | Lots of BBC into TF out there. It's more of an adapation than a swap. I put one from a 72 C20 with TH400 in my 57 last year. It is a 3600 and had a 235 w/4 speed hydromatic. 1. remove everything from firewall forward, sheetmetal, engine, etc. 2. 'hang' the new engine/trans with motor mounts and manifolds on it in place on hoist as low and starboard and aft as you are comfortable. maybe 1 inch from the frame, firewall, steering gear, etc. 3. build some motor mounts from channel, or buy a universal pipe type, and a transmission mount. 4. measure and build a driveshaft. I was lucky the open shaft from the hydro mated with the output shaft from TH400 via a U-joint. 5. build/adapt a transmission selector lever. The hydro column selector made it easy. 6. build/adapt a throttle lever/cable. 7. fabricate a couple exhaust pipes that will fit. 8. carfully fit the old cooling fan to the waterpump in the inch or so you have allowed for the radiator, add a transmission cooler. 9. adapt some radiator hoses, fuel lines, 10 hook the HEI to your ignition switch and you are done.
" the first rule of the intelligent tinkerer is to save all the parts" aldo leopold
