3 members (Gdads51, Raymond HAYWOOD, IHPWR), 175 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#71485 01/11/2007 1:55 AM
What is the axle diameter for a 51 GMC 1/2 ton? I need to make sure mine are within tolerances at the place where they will contact the rear wheel bearing.
#71486 01/11/2007 3:11 AM
If you have ridges on either side of where the bearing runs it is worn.
Does the shop manual give a spec for it?
What does it measure now, at the smallest part where the bearing runs? Then what does it measure at the largest part beside where it is worn?
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
#71487 01/11/2007 3:14 AM
I can't find anything about it in the shop manual. I think I measured 1.88 or 1.89 inches with a micrometer just in the center of it. It doesn't really have any definite ridges, not even enough to catch a fingernail on.
#71488 01/11/2007 3:17 AM
I actually measured it with a dial caliper, so I am not sure if it actually reached far enough to get the measurement right.
#71489 01/11/2007 3:20 AM
Then it may not be worn if you can't feel anything.
Measure the diameter, out to 0.001 or better, in many different places and lets hear the largest and smallest.
Grigg
---All pictures---
#71490 01/11/2007 3:25 AM
Do you have a micrometer?
How confident are you with taking accurate measurements with a dial caliper? If you have a good sense of feel you should be able to decide if it is worn too much or not with the calipers.
Grigg
---All pictures---
#71491 01/11/2007 4:02 PM
I just think that the backside of the caliper may have hit the axle before the measuring arms reached the largest point of the axle. I will measure again from different sides and post the measurements. Does anybody have the correct diameter from the manual?
#71492 01/14/2007 9:05 AM
If you have measuring tools you can measure the inside diameter of the bearing race since it never wears except in a total failure. This will be the OD of the axle where the bearing fits.
Evan
#71493 01/14/2007 3:13 PM
I think that the bearing rollers run directly on the axle shaft?
---All pictures---
