1 members (Rnl364), 104 guests, and 6 robots.
Topics128,077
Posts1,056,033
Members48,433
#714672 01/24/2011 1:14 PM
Ordered a TMC carb for my 235 L6.suppose to fit.At local parts house.Never heard of it.Got tired of fighting that Rochester on it.Is this a decent carb?
dtwbcs #714673 01/24/2011 1:24 PM
what is a TMC carb?
brokenhead #714679 01/24/2011 2:12 PM
I expect TMC is the initials for TOMCO, the carb rebuilder that O'Reilly sells.
A TMC 1-06 is a Carter YF for a 235.
A TMC 1-12 is a Rochester B for a 235.
So, if the OP ordered a 1-12, he's setting himself up for a disappointment.
regards,
Leon
Leon #714816 01/24/2011 11:55 PM
so i want the tmc 1-06 right?then it should resolve my issues about the carb,huh?
dtwbcs #714840 01/25/2011 12:59 AM
Carburetion specialist
One major problem with buying a rebuilt carb through a parts house is grouping. The rebuilder groups many different original carburetors together, and then builds to his own specifications. Then the rebuilder assigns his own part number to the new specification, and provides an interchange to his specification.
Sometimes the groupings are relatively decent. Sometimes they are not.
If the OP wants a Carter, then here is a suggestion: take a look through the archives on this forum. I have listed each of the Carter YF carbs that work on various Chevrolet 6 cylinder engines.
Find the specific carb (ebay is one source); obtain a rebuilding kit, and rebuild the carb yourself. It is not rocket science.
Jon.
The Carburetor Shop
carbking #714907 01/25/2011 4:15 AM
I have rebuilt several rochester carbs.All with varying degrees of success.That is why I chose to get one that is remanufactured.Can only hope that the person who rebuilt the particular carb has more knowledge&experience than what I do-(just going by the vague directions included in kit)when it comes to carburetors.Or you would think that they would know,at least,what/how it should be rebuilt.
Just my 2cents-
Danny
1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
carbking #715329 01/26/2011 11:55 AM
what are the model #'s of carter yf carbs that fit a 235engine(car)?What about a gmc270truck?
thanks
dtwbcs #715723 01/27/2011 5:10 PM
1937 Chevy 1/2-Ton
wasat again #716148 01/29/2011 1:03 AM
--guess i need to call them --
Danny
dtwbcs #716152 01/29/2011 1:13 AM
I was told Tomco went out of business. If TMC is truly Tomco, avoid them like the plague. I have 2 Tomco reman Carters, boht supposedly for a 235 Chevrolet w/manual choke. Turned out one was actually a FORD (!!!) YF, which is jetted way too rich for use on a Chevy.
Personally, I would suggest combing the local salvage yards, find an original carb, and rebuild it yourself. That's what i ended up doing, using IH sourced Holleys that I rebuilt and matched up myself, couldn't be happier with the results.
Bill Burmeister
LONGBOX55 #716263 01/29/2011 11:17 AM
Hey!now thats an idea that I didnt think about.I wonder if there is one close by in Tx.I know alot of places "crushed"the older cars/trucks around here-
Danny
