| | | Forums66 Topics128,078 Posts1,056,053 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 19 New Guy | | New Guy Joined: Jan 2006 Posts: 19 | Does anyone have a picture of a repaired rear cab support on a 60 apache? I am getting ready to replace my supprot/brace and I would really like to see a picture of a finished one.
Paul | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The cab support on the underside of the cab, itself or the frame-to-cab perches, factory riveted to the frame? | | | | | Joined: Jan 2006 Posts: 19 New Guy | | New Guy Joined: Jan 2006 Posts: 19 | The cab support on the underside of the cab. I am going to replace mine this weekend and I need a picture - mine are pretty bad and I am not sure I can figure out placement without a picture.
THanks,
Paul | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | A patch panel is available for the rear cab support, both full & slip-over. I would stay away from the slip-over, since it is just covering up the problem, in lieu of fixing it. The supports are self-aligning, since they will only fit in one direction and relative to what is removed. | | | | | Joined: Jan 2006 Posts: 19 New Guy | | New Guy Joined: Jan 2006 Posts: 19 | I have the full patch panels ready to go - I just want a picture of what they are supposed to look like when they are finally installed.
Paul | | |
