1 members (klhansen),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#71432 01/10/2007 1:34 AM | Joined: Nov 2006 Posts: 61 Member | | Member Joined: Nov 2006 Posts: 61 | Both of my 250 engines have 1bbl carbs. I am wondering what common ( not special ) 2bbl will or can be used. What do you folks recommend. Thank you. Slider
Jesus is Love! Never forget the Veteran. AND God bless Amercia!
#71433 01/10/2007 5:34 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | There are no 2bbls common to the 250. The exception is the later 250s with the integral head came stock with a 2bbl. Hope that helps.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
#71434 01/10/2007 8:05 AM | Joined: Oct 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 62 | did Pont, olds, or buick make a 250? did they have 2bbl intakes? would those work on chevy? I am also trying to seperate 250 fact from fiction ya got me curious too slider
I see a GM truck in your future!
#71435 01/10/2007 2:40 PM | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I'm not sure what the years are on your 250's, but I'm sure someone makes a 2bbl to 1 bbl adapter plate you can use. Not to take away from anyone who wants to keep their ride orginial as I like them alot. On my 250 I just didn't want anything more to do with the old Rochester 1 and 2 barrel carbs. Just look at the many past posts, including mine, on this site and you'll see what I mean. The reason I first showed up here was trying to deal with two old "B" model Rochesters that cost me an engine rebuild. I ended up putting a 390cfm Holley 4-bbl on top of a Offy intake and the difference is unreal. It still gives me a great deal of pleasure to be on a rod rod with my buddies starting out in the morning from a motel. My 250 roars to life with a bump of the key when their 350 sbc grind away for several plus seconds to bring them to life. Another great thing is when you are showing off your engine. You will get many onlookers calling their buddies over to take a look at the "hot" 4-bbl setup setting on 6-banger.
#71436 01/10/2007 3:50 PM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Again There are no 2bbls common to the 250 in any GM vehicle made in the USA.  The exception is the later 250s with the integral head came stock with a 2bbl. I did forget one other exception.  There is a 2bbl manifold that was made in the southern hemisphere. I've seen pictures of it, I have not heard of anyone getting one up here. Evidently GM did develope the L6 a bit more for south America. There may even be another head for 250 down there. Beltfed is right you can either use a 2bbl adapter to the stock manifold or an adapter on a Clifford or Offy manifold. If you have the tools you make an adapter plate to bolt to the stock manifold for a 2bbl. You have to flatten the top of the manifold, hog out the stock hole, and make a gasket. Larry
#71437 01/10/2007 4:34 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you don't have the integral manifold head, you could use a manifold from a late 292. They had 2 bbl carbs- Rochester 2SE progressive type. It is more or less a Q-Jet primary and secondary. Not a bad carb if tuned right and kept clean.
Bill Burmeister | | |
#71438 01/10/2007 4:54 PM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Longbox55, I've never seen or heard of any other manifold other than the Integral head and the south American that used a 2bbl. I have heard that the 2SE is a nice carb, it is also what they used on the Integral head. Could you give a little more detail as to what late model 292 used that carb other than the integral head. I sure would like one for my 292. :confused:
Larry
#71439 01/10/2007 11:22 PM | Joined: Nov 2006 Posts: 61 Member | | Member Joined: Nov 2006 Posts: 61 | Longbox55, Thanks, did i understand you to say that late 292`s have a two (2) bbl intake manifold? That would be cool. Can you verify that for me? Thanks. This looks like a good topic we have going here
#71440 01/11/2007 2:07 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I think I may have goofed. I could have sworn I saw that info on the 2 bbl on a 292 in a shop manual, but so far all the spec books I've checked say single bbl on 292. I also seem to recall the shop my dad used to work for had an '80-'82 (?) C20 that had a 292 with 2bbl. I'm going to look around some more, see if I can find that manual that I saw it in.
