5 members (klhansen, TUTS 59, papas52, 78buckshot, 1 invisible), 91 guests, and 2 robots.
Topics128,186
Posts1,057,308
Members48,468
I have recently aquired a 1957? fire truck, the bed has been recently removed so now it is just a big cab and chassis. this is a stock V8 truck and I am not sure what power plant it is (small block chevy but what size?) I also don't have any idea what the shift pattern is for the 4x4 transfer case and trans. Any help with this would be appreciated. This truck does run and I drove it part of the way home (I was pushed the rest). It has accured to me that the gas gauge is not reading correctly.
Moderator
Moderator
2 Offline
Mark
Welcome to the Stovebolt Page. You will be getting a lot of help here as soon the people start getting off work and set down to read after dinner.
2-Ton
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
If indeed the chassis is a 57, there were only two V-8's available then, a 265 cubic inch, and a 283. Assuming it's got the original engine still in place, look for a machined pad just ahead of the passenger's side cylinder head and copy the letters at the end of the stamped number. Someone here should be able to decipher the engine size and application from that suffix. There are several online lists of engine ID codes.
Welcome to the nuthouse!
yes Mark, welcome to the garage ... a GMC wouldn't originally have been a SBC, but a Pontiac - 316, 336, or 347 I believe in the 55-59 years
OOPS! I missed that! It would be a Pontiac engine in a V-8 GMC!
Welcome Mark!
Check out my 57 Chevy Fire Engine and my 56 Chevy NAPCO 4x4 on my web page.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Not sure if a 2 ton is big enough, but gmc also offered the oldsmobile engines in the larger trucks. 371 Olds perhaps?
Are you sure the engine is a SBC? Does the engine have small hoses coming out of the water pump and going to the heads? If so you likely still have the reversed cooled Pontiac engine.
Sounds very interesting! Pictures are always appreciated!
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
A GMC up to a 500 series would be a Pontiac engine. 550 and 600 had the 371 Olds from 57 to 59. 55,56 550 and 600 had the 324 Olds.
yea but after all these years...its probly a sbc.
crenwelge, My truck is a 370 and I believe you are right it should be a Pontiac engine. I thought the 1/2 & 3/4 ton trucks were 348's and I did not know about the larger 370. By the way I also own a 56 gmc 100 4x4, I have had this truck for about 30 years and started restoring it about three years ago. It is not stock and I think it is really a money sponge and not a truck. However, I still love it.
