1 members (CuzzFuzz),
83
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | ...And it is available for sale. It is attached to what appears to be an SM-420 transmission. I am not that familiar with it, but it sure looks like a very old transfer case that might have been a dealer-installed option.
At first I thought I wanted it, but decided not to go that direction. Never the less, the owner did say he'd sell it. I don't know what he wants for it, but I'll bet someone here might be highly interested.
If so, let me know. I can take pictures and send to you. This is located in Clovis, New Mexico, and this is truck country. He also has some Chevy and GMC trucks, as well as Ford and Studebaker. They are all restorable, but they need everything gone through.
Anyway let me know if anyone wants more info on this...
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Feb 2004 Posts: 29,817 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,817 | If it's a "married" unit with a motor mount sandwiched between the transmission and the transfer case, I doubt it it's old enough to be a NAPCO transfer case. I believe all of them were mounted separately, with a short driveshaft as a connector. The later models had a cast iron rear motor mount bracket that served as the splice between the units. Jerry
| | | | | Joined: Dec 2010 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 62 | I'm interested in the napco. Do you have contact info? | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I can certainly get contact info. Let me provide a link to a photo of the tranny/xfr case I took today. As you can see, it appears to be an SM-420 on the front of it. Let me know if anyone's interested and I will provide the guy's contact info. (Got to go back over there to ask him for it. I talked to him today again but didn't think to write down his number). Also, let me know if anyone wants a stovebolt truck to restore. He's got a few of those too. Here's the link for the photo. Izzat a Napco? Front view: [IMG] http://i664.photobucket.com/albums/vv9/axeimen/Napcofrontview.jpg[/IMG] Rear view: [IMG] http://i664.photobucket.com/albums/vv9/axeimen/Napcorearview.jpg[/IMG]
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Definetly not a Napco. Just judging, with the drivers side output and the shape of the shifter, it's an early '80s Ford transmision and 'case, porbabply from a 1/2 ton.
Bill Burmeister | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Okay, well thanks for the confirmation. Too bad. I thought someone here would be able to use it. | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Okay, well thanks for the confirmation. Too bad. I thought someone here would be able to use it. | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | That is not a NAPCO unit to be sure. They are "divorced" transfer cases. This is a NAPCO t-case (note that the PTO is not normally there): From the back Out of the truck front of t-case Cleaned up and in truck You can find NAPCO running gear on Ebay quite often or you can go to one of the NAPCO4x4.org forum for parts. | | |
