1 members (Southerntruck),
148
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 10 Member | | Member Joined: Feb 2003 Posts: 10 | Once again, I approach the fountain of knowlege for a drink. A local bargain trader has used Chevy 350 LT1 V8 small blocks for sale. Some have Aluminum heads ($650) and some have cast heads ($350). From the photos, they appear to be minus intake and flywheel. My question is: What does "LT1" mean? Is it 4 bolt main bearing caps, or does it have to do with other special feature? Do you think the asking price is reasonable? THANKS.
Regards, Emil
| | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Emil; Not sure what LT1 stands for maybe chiphead does, but the price is only as good as motor, we've bought 350's from $25.00 (demo derby cars to $750.00 rebuilt short blocks)all said and done I've got about $1,800.00 in mine doing most of the work myself. I don't want Maws and me to break down in 59. popcorn | | | | | Joined: Feb 2003 Posts: 10 Member | | Member Joined: Feb 2003 Posts: 10 | I assume these engines are rebuildable cores. That's why I thought LT1 must mean something valuable to be asking that much. I will call them just for grins.
Regards, Emil
| | | | | Joined: Nov 2002 Posts: 4 Apprentice | | Apprentice Joined: Nov 2002 Posts: 4 | LT-1 350's first appeared in 1969 Corvettes and was available in the 70 1/2 Z-28 Camaro as well as Vettes. Specs: Displacement 350 ci Bore and stroke 4.00 X 3.48 Horsepower 360/370 @ 6000 Compression 11.0 to 1 Chamber design Wedge Carburetion 780 cfm Holley Intake Aluminum high riser Camshaft .458/.458-inch lift,317/346 deg duration Lifters Solid Valves,int/exh 2.02/1.60 inch Pistons impact extruded aluminum Rods forged steel Crank forged steel Exhaust Dual,cast iron headers Ignition Single point,vacuum advance Fuel required Premium Heads had screw in studs Four - bolt mains
70 GMC 7500 Tilt Cab 88 GMC G2500 Conversion 61 Massey Ferguson 35 74 John Deere 2130 81 Massey Ferguson 60 Backhoe 83 GMC C10 90 Navistar 4900 83 Honda CB1100F 73 Harley Davidson FXE 68 Chevrolet Impala SS 92 Chevrolet G1500
| | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Don't know for sure, but chevy prolly recycled the LT-1 designation from the late '60s when they came out with the new & improved model in the '90s.
The '60s LT-1 would be a nice engine to have if you could find one that wasn't blown to bits. It follows most of the typical rules of a performance 350.
The '90s LT-1 was a reverse cooled, computer controlled engine. It uses serpentine belts, a special MPFI intake, special electrical system & all those sensors & powertrain control computers. It'll make great power if you can find all the electrical & electronic gizmos to go with it. I could be wrong, but I believe that these motors are related to the late '90s & up LS-1 engines used in F-bodies & vettes, that had a carbon-fiber intake, coil-on-plug ignition, reverse flow cooling system, etc.
Basically the '90s LT-1 & LS-1 350s are related to the older 350s in displacement alone. Not many parts will interchange, including the accessories, electrical and cooling systems.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
| | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | A friend of mine had one in a 94 caprice cop car,a good running motor but has alot goofy stuff on it like a behind the waterpump front distributor,a cam driven waterpump and more. I think they can be converted to normal but might be better to find a regular 350 | | | | | Joined: Feb 2003 Posts: 10 Member | | Member Joined: Feb 2003 Posts: 10 | Lots of great info, I printed that article from Automotive Rebuilder and will be reading it a few times. The fact about the later models needing the ancillary parts and computer controls to work right will kill it for me. I didn't see a distributor in the photo either ($500-$600 egad!) or water pump or pulleys, etc. Thanks all for helping me avoid a costly blunder. I will be studying a bit longer on this.
Regards, Emil
| | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | while the info provided was accurate, and interesting, it tells a part of yer question. general motors uses these numbers to designate a series of engines. big blocks are l-88 (old 427's) ls-6 (454) lt-1 (performance 350). etc. there are several designations of engines. oh yeah---old 350's really don't like new 350's. unless you are racing the numbers don't mean much if you are staying close to stock. a buddy of mine bought a new vette and was bragging about how fast it goes. i ask him if he's ever raced it---he asks me if i'm crazy. i ask him if he's ever had it over a hundred---he asks me if i realize just how expensive the car is. i look at him and smile and tell him how fast my junk pickup goes--and tell him i know it for a fact, cause i drove it that fast. then i ask him if he would have been better off with a v-6 and saved his money. he ain't never gonna use the power, so why have it. the point? well, if you ain't racin' how about taking a good engine and rebuilding it to reliable? add a few improvements to the intake, exhaust, and ignition system to make a solid reliable street ride. throw away the original cam. it makes a great ashtray stand. the lt-1 is a good engine, and i have run a few, but not necessary in a normal ride. save yer bucks  | | |
