4 members (DoubleB, greenie-reddy, 41appletruck, Oswald), 85 guests, and 1 robot.
Topics128,091
Posts1,056,038
Members48,433
#713765 01/21/2011 4:48 AM
Was thinking about staying stock, but after considering my commute I'm gonna need the ever popularly discussed highway setup. It's about to get a 350 V8 and I'm considering a T-5 to replace the 3-speed SM-318. Anything in particular I'm going to need to put one in?
62' GMC SWB Fleetside
Why can't we just go back to the designs from when cars were unique and didn't all look the same?
keilkravec #713926 01/21/2011 6:11 PM
Riding in the Passing Lane
It is an easy swap & the results are rewarding. Study the tech tips & search the other posts. There has been much discussion on this. You will need a special clutch disc, a crossmember to go in the rear on the trans, & have the drive shaft shortened.
Remember these are not real strong trans. I have put them behind 350's & run one now, but you can't go out there & do burn outs & speed shifting.
1972 Chevy c10 Cheyenne Super
Yea I've poked through those but not really found anything i can use, thankfully I've been lucky enough to get 3 drive shafts with my truck when i bought it so that parts taken care of..what kind of clutch disc am I going to need exactly? Not really well versed in that area, and for the crossmember am i going to need fabrication work or can the stock be modified a little to fit?
keilkravec #713953 01/21/2011 8:59 PM
The whole prosedure is in the thread curently active in the Crash Box section. What to grab for a T-5 swap. Bowtie tim gives part numbers for the clutch disc or if you have a clutch shop nearby they can make one up. If you have an automatic you already have a crossmember at the rear of the trans. You can get a universal one or fabricate one. Some guys run without one like the original cast iron trans. but I sure wouln't with that long thin alum. one.
