| | | Forums66 Topics128,094 Posts1,056,051 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 66 | I need a good install plan ,with good pictures of transmission and motor, for a newport engineering windshield wiper system. Does anyone have one or know of a good resource? I have a 1952 Chevy Pickup.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Here is a link to a few pictures of a Newport installed in my 50 newport pics link This is the Newport model that clears the stock choke, May not be the same as yours. The Pic with the tape measure has the transmissions arms installed incorrectly. Good Luck | | | | | Joined: Mar 2007 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 66 | Thanks to Dads50 for the fantastic pictures. Newport Engineering sent me some good drawings as well. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The instructions Newport provides are very good.
I did use longer 10/32 screws and large washers instead of the screws that came in the kit. Got the screws at the hardware store.
I had to adjust the park on my motor.
Once you get it mounted and transmission arms installed you may want to run a wire and check for binding on the arms.
If your using the stock choke cable install it and check for interference.
Newport sells two kits for AD trucks. One will interfere with the choke and maybe original radio.
NE4753CCT clears the choke, NE4753CT will not. Good Luck
| | | | | Joined: Mar 2007 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 66 | Thanks to all of you. This helps. Newport also sent me some pretty good diagrams. | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Good picks on the install, I think that might be my next project, will be easier following your installation! Thanks!! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | This thread makes me SICK!!! I have been following it for a while and had decided New Port was the best and the only one for me. However as I was going through all my parts bought months ago I found the electric wiper motor from LMC I had forgotten I had bought. I sure hope this works out as I don't want to invest in another motor.
~Jim
| | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | I think Newport Engineering may have improved on their wiper system. I'm currently using The Specialty Power Windows Wiper System, which has worked perfectly for the past 4 years of everyday use. Prior to that the Newport system didn't last more than 3 years, problems with motors and switches of everyday use. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Not to beat a dead horse........but my Newport Delay box that I added to my Newport wiper motor has a mind of it's own.....the vendor recommended "adjusting" the wiper motor!!! Obviously, he had never had any experience with the non-adjustable module and was hoping I would just let him off the hook. They weren't at all interested in offering me a replacement module to make my system "right." So it "wipes" correctly about 50% of the time and the rest of the time it "parks" itself where ever it wants and you have to cycle the switch to get it back to wiping.
Let the buyer beware!!!!!
Dave | | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | So does Newport sell direct or thru dealers? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | both, but usually the vendors don't specify if they stock Newport or Chinese knock offs, so ask! http://www.newportwipers.com/ | | |
