1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 43 New Guy | | New Guy Joined: Oct 2010 Posts: 43 | Was thinking about staying stock, but after considering my commute I'm gonna need the ever popularly discussed highway setup. It's about to get a 350 V8 and I'm considering a T-5 to replace the 3-speed SM-318. Anything in particular I'm going to need to put one in?
62' GMC SWB Fleetside
Why can't we just go back to the designs from when cars were unique and didn't all look the same?
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It is an easy swap & the results are rewarding. Study the tech tips & search the other posts. There has been much discussion on this. You will need a special clutch disc, a crossmember to go in the rear on the trans, & have the drive shaft shortened. Remember these are not real strong trans. I have put them behind 350's & run one now, but you can't go out there & do burn outs & speed shifting. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2010 Posts: 43 New Guy | | New Guy Joined: Oct 2010 Posts: 43 | Yea I've poked through those but not really found anything i can use, thankfully I've been lucky enough to get 3 drive shafts with my truck when i bought it so that parts taken care of..what kind of clutch disc am I going to need exactly? Not really well versed in that area, and for the crossmember am i going to need fabrication work or can the stock be modified a little to fit?
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The whole prosedure is in the thread curently active in the Crash Box section. What to grab for a T-5 swap. Bowtie tim gives part numbers for the clutch disc or if you have a clutch shop nearby they can make one up. If you have an automatic you already have a crossmember at the rear of the trans. You can get a universal one or fabricate one. Some guys run without one like the original cast iron trans. but I sure wouln't with that long thin alum. one. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
