0 members (),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,078 Posts1,055,938 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | I'm considering purchasing a take-out engine/4-speed trans assembly from a stovebolt truck, not sure of the year. The stamped number behind the dizzy begins with "DCM" followed by a 6-digit number which makes me think it might be a 1946 model 235, but that alpha code gets skipped in the code lists I can find. Anybody got any words of wisdom? Jerry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Jerry, according to the GM Heritage site, it's a 1946 Tonananda produced 216 from a 1 1/2 ton truck.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | OK, thanks! I assume the trans would be a crash-box 4-speed? Those little details will influence what I'm willing to offer. Jerry
| | | | | Joined: Jan 2011 Posts: 15 New Guy | | New Guy Joined: Jan 2011 Posts: 15 | I'm thinking the crash box has the lock out 'trigger' for reverse? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | From a 1984 article from the Light Commercial Vehicle Association magazine (which later became "This Old Truck" magazine and is now called "Vintage Truck" magazine:
"In 1948 Chevrolet was the first of the volume manufactures to offer a 4-speed synchro-mesh, helical gear transmission as regular equipment. It was an extra cost option. As a result of this complete redesign, the 4-speed transmission case was wider, higher, and longer. It was still of the same rigid, box-like cast iron construction as before. So that the new 4-speed transmission could be mounted interchangeably with the 3-speed transmission it was necessary to increase the length of the 3-speed transmission case and main shaft. Minor changes were made to the dash and tow panels in that a new seal was added to accommodate the steering column, gearshift, and the transmission cases. The new foot operated parking brake was moved to the extreme left side of the cab. A hand release rod was located just below the instrument panel. The foot operated parking brake offered a couple of advantages, it was easier to apply because more pressure can be applied with the leg and it helped to provide smooth starts on hill by allowing the driver to simultaneously accelerate the engine, engage the clutch, and release the parking brake lever. Only a slight amount of effort was needed to release the parking brake because of an 8 to 1 mechanical advantage. A new left-hand inner fender skirt was provided to allow space for the pedal mounting lever."
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2011 Posts: 8 New Guy | | New Guy Joined: Jan 2011 Posts: 8 | Hi I am new here dont know where to post this ..found a old inline 6 some one may want it. i am in Texas motor is south SD | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Billy go back to the start page on the forums, and post a new topic in the parts for sale section, welcome. | | | | | Joined: Jan 2011 Posts: 8 New Guy | | New Guy Joined: Jan 2011 Posts: 8 | | | |
