8 members (Ponchogl, Bill Hanlon, MickeyP, Hotrod Lincoln, Hanks custodian, Otto Skorzeny, Charles in CA, 48ed56pam),
172
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,071 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#71306 01/07/2007 9:00 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Bought a rebuilt shift box which mounts on the column of my '49 GMC. Took it apart to do some work on the shift arms and now can't figure out how the spring hooks up to the arms inside the box. I know that the lower arm (towards the steering box) part of the spring has a hook on it and it fits nicely around the arm. But how does the spring hook or fit around the upper arm? It looks like the spring that I have may have had a hook as well but now only has a small bend in the end of it. Is the upper arm supposed to be under some tension to move it upwards or downwards? Thanks in advance! | | |
#71307 01/07/2007 9:09 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It,s been a while since i,ve been in one of those but the spring keeps it in 2-3 untill you pull it forward for 1&R. There is no spring to pull the levers up or down. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#71308 01/08/2007 4:03 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Then what you're saying is that the arms are free to move up and down in a motion perpendicular to the shaft without spring tension on them and that the spring only keeps them apart inside the housing in a plane that is parallel to the shaft. Kinda hard to explain. | | |
#71309 01/08/2007 10:31 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes I know it,s hard to visualize & explain. The spring pulls the shaft towards 2-3. Therefore you have to pull foreward to shift to 1st & R. The levers like you say are free to go up or down, depending on which position the noggin on the shaft is in. The trans. cover has lockouts that keep it from going into 2 gears at once. If the lever gets hung up there is to much gap between the levers or the noggin is worn down. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#71310 01/09/2007 1:53 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Thanks! Will fart around with it this weekend. | | |
