| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 33 New Guy | | New Guy Joined: Nov 2009 Posts: 33 | I need some input. I am switching to four wheel disk brakes on my 50 3100. I have been looking online for information about which master cylinder to use some web sites say I need one with a 1 1/8 bore and some say 1-inch. which is correct
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy mustache man, a lot would depend on the type of caliper you are going to use, multi-piston calipers would require a larger volume. If in doubt go with the larger bore, hope that helps. | | | | | Joined: Nov 2009 Posts: 33 New Guy | | New Guy Joined: Nov 2009 Posts: 33 | thanks 3b i have single piston gm calipers and a 7 inch double diaphram power booster | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 |
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | There was a previous post (which I can't seem to find) where one member discusses the math that compares the pressures created between a one inch bore and a larger one. Anyone remember that one?
It's a small world, but I wouldn't want to paint it.
