6 members (Bill Hanlon, Donf, MickeyP, Hotrod Lincoln, mick53, FAST55), 109 guests, and 1 robot.
Topics128,049
Posts1,055,701
#71279 01/07/2007 5:43 AM
Now that the 265 is running...I want to get the SM420 hooked up to it. I have the bellhousing in place, but the tranny I bought didn't come with bolts. Anyone know the size/type required for this?
Thanks-Dano grin
my truck gets better every day...every PAYDAY smile
#71280 01/07/2007 6:33 AM
H Online: Content
If you're talking about the transmission-to-bellhousing bolts, they're 1/2" X 13. (1/2" coarse thread, 3/4" wrench size) The lower legs of the transmission will have those threads, and the bolts come through the bellhousing and screw into the transmission. If you want the strongest bolts commonly available, buy Grade 8 bolts, with 6 lines on the head. The standard bolt is a Grade 5, with 3 lines.
#71281 01/07/2007 6:49 AM
Thanks Hot Rod Lincoln!! That's exactly what I needed to know!
Dano
#71282 01/07/2007 7:48 AM
A pair of 235 head bolts with the heads ground off of them make dandy guide pins for re-installing an SM 420, too. Those things are heavy!
Paint & Body Shop moderator
