| | | Forums66 Topics128,026 Posts1,055,406 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | hello i've been sifting through the posts in this forum for a couple of weeks now and have yet to see one like this i have a 54 235 the number stamped behind the dist is F54Z it also has a data plate rivited above the block casting # ( 3835911) that indicates that it has been over hauled job #, cyl .030, journals .010, etc i'm curious if that means gm did the work? my problem is that i can't get the cam out. folowing the instructions i downloaded from this site and those in the 54 fsctory manual- once i pulled the crank gear i rotated the cam looking thru the holes found 3 bolts instead of two screws. i removed all 3. then when i tried to slide the cam out it only moved a quarter inch before it hit on something. i can't see anything that would hang it up there are two screws on the front plate. i broke a screw driver trying to take one out. the other is behind the cam timing gear and the hole does not allow access i quit at that point. what have i missed that will let me get the cam out? thanks
1963 c10 | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | is it hitting the crankshaft? | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | You have to pull out the lifters in ordeer to remove the cam. | | | | | Joined: Apr 2005 Posts: 32 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 32 | You need to remove the distributor and the fuel pump along with the lifters. As you slide the cam forward check to make sure the lobes are not hitting the crank, also support the cam so the lobes don't scrape the cam bearings. Good Luck.
Bill garvey
| | | | | Joined: Apr 2005 Posts: 32 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 32 | If you plan to re-use the cam and lifters , make sure the lifters are returned to the same holes. The tag with the number on it indicates your block was rebuilt by an independent rebuilder.
Bill garvey
| | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | thanks guys the engine has everything removed except the lifters they have a lot of rust and crud on them and don't want to come out eventhough the motor is upside down. the crank is out of the way and i'm pretty sure the lifters are not hitting the cam lobes i'll try again today to get the lifters out
everything was coming off so well..... thanks
1963 c10 | | | | | Joined: Oct 2010 Posts: 45 New Guy | | New Guy Joined: Oct 2010 Posts: 45 | There's probably a lifter hanging down in the way. The lifter body just above the cam lobe never goes completely into the lifter bore; in time, this area collects a varnish coating so the lifter doesn't want to move up farther than it ran. Use a wood dowel rod to knock the lifters up enough to get the cam out, then drive the lifters down and out. | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | sure enough it was the lifters. once i got them out of the way the cam came right out thanks guys i'm waiting on one valve to have the head done and a cylinder ridge hone to get the pistons out so far she looks good and i have a lead on amachine shop to get her cleaned up i'll be in touch thanks again
1963 c10 | | |
