7 members (dgrinnan, Scott '48 2ton, Wayne67vert, Jon G, NorthCoast3800, Gray_Ghost, Peggy M), 103 guests, and 3 robots.
Topics128,163
Posts1,056,962
Members48,458
I would like to find an electric cut off saw which operates the small 3 inch discs, 3/8 arbor. I've seen many that are air operated, any suggestions.
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
I use my angle grinders more for cutting than I do for grinding. They use different wheels, though.
Ed Miller
'58 Apache short Fleetside half ton Napco
Falls City, OR
blanch53 what type of work are you wanting to do with it ?
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
The main use is to cut out some rusty metal on certain body panels, and inside the cab. This type of tool would allow for cutting close up to corners etc.
These type die grinders are for grinding not a cutting wheel.
http://www.toolbarn.com/power-tools/electric-tools/grinders/die-grinders.html
You may want to try a body saw not my type of brand I like but a example. http://www.harborfreight.com/electric-body-saw-65766.html
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
I don't know how close of quarters you are working in, but you might like to use a Dremel Tool with cut off wheels. I am working on the interior cowl panels, and you get very precise cuts with the Dremel. I use tape as a cutting guide, plus you don't remove as much metal. Also use a full face protection mask as the Dremel wheels are a little soft and can shatter as they wear down.
Moderated by  MNSmith
