| | | Forums66 Topics128,196 Posts1,057,390 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 38 | I an going to reinstall the axles. How is the axle flange sealed to the hub? When I took it apart, it had aluminum shims or gaskets. I purchased (NOS) what were to be gaskets for the axle flange; they are steel. Are they really gaskets or shims? Should I use gaskets cut from gasket material? Are shims needed? How do I finish this job? | | | | | Joined: Dec 2010 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 48 | The factory manual says to make sure the surface is completely clean and oil free or the axle bolts will loosen up on their own. The gaskets are a soft alloy. They will crush some. I got some at NAPA recently. Whatever you do don't use gasket material! I can go get the FelPro number off them if you want. If your NOS gaskets are rusty at all don't use them.
1950 3804 Pickup
| | | | | Joined: Aug 2010 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 38 | Thanks for the info. The NOS gaskets that I have look good. Keep the FEL-PRO number handy just in case.
Speaking of Fel-Pro, do you know of a good inclusive catalog source for their products? I was unable to find a banjo gasket on-line. I finaly got one through o'Riley auto parts. | | |
