I purchased a seat cover what came with door boards and extra material to match the seat insert cloth on the 57 Chevy 3100 with deluxe cab.
I got the cameo style seat covers to dress it up a bit and wanted to put the door insert boards on too with the seat material.
What is the correct way to attach the material to the board? 3M spray-on cement or something?
And then how do they attach to the door itself?
It has two holes for the window and door crank but none for the door handle. Guess I will have to drill those holes for the door handle.
But will it stay in place with just those 3 things (4 holes) holding it or is there some other trick?
I have seen some screw it in but then others do not appear to have screws holding it on.
Also I have bought the back board (vinyl covered) to match the seat vinyl and cover the spings in back, but I do not see an obvious way to attach it to the back of the seat.
How do you do that?
