4 members (Samantha, KEVINSKI, mk72, 55shaker), 91 guests, and 2 robots.
Topics128,035
Posts1,055,552
#711915 01/14/2011 11:06 PM
I
I Offline
I inherited my great grandfathers 1950 6400 truck I have the title but I have no clue where the Vin # is. Can anybody tell me where it is located?
Thanks for any help.
idahoplowboy #711918 01/14/2011 11:17 PM
Look on the driver side door opening about 3/4 of the way down this is the only Vin you will find but it may be titled by the engine number which is located in picture 2. Compare and then you can see which is which.
http://good-times.webshots.com/photo/2055765980102454676uUharU
The engine number is located here, see the flat pad right behind the distributor that is where you will find the engine number.
http://good-times.webshots.com/photo/2764123730102454676sHpKqR
Brad Allen #711919 01/14/2011 11:28 PM
I
I Offline
Mine is missing from the left door post, What can I do now?
idahoplowboy #711955 01/15/2011 2:14 AM
Have you looked at the engine. Most states titled by engine number in 1950.
crenwelge #713005 01/18/2011 4:56 PM
Apprentice
Apprentice
and it isn't a vin....it's a S/N that you can use when registered as a vin...it's not as long.
52FamrME #713059 01/18/2011 8:45 PM
Depends on the state in Utah the data plate number is the VIN.
Brad Allen #713666 01/21/2011 12:24 AM
I
I Offline
I have the title and it shows the S/N and motor/# I guess I will look at the motor for that # when I get it in my yard.
