6 members (klhansen, JoergK., Gray_Ghost, Jay R, Hotrod Lincoln, dbwr), 162 guests, and 1 robot.
Topics128,190
Posts1,057,342
Members48,469
I an going to reinstall the axles. How is the axle flange sealed to the hub? When I took it apart, it had aluminum shims or gaskets. I purchased (NOS) what were to be gaskets for the axle flange; they are steel. Are they really gaskets or shims? Should I use gaskets cut from gasket material? Are shims needed? How do I finish this job?
The factory manual says to make sure the surface is completely clean and oil free or the axle bolts will loosen up on their own. The gaskets are a soft alloy. They will crush some. I got some at NAPA recently. Whatever you do don't use gasket material! I can go get the FelPro number off them if you want. If your NOS gaskets are rusty at all don't use them.
1950 3804 Pickup
Thanks for the info. The NOS gaskets that I have look good. Keep the FEL-PRO number handy just in case.
Speaking of Fel-Pro, do you know of a good inclusive catalog source for their products? I was unable to find a banjo gasket on-line. I finaly got one through o'Riley auto parts.
