6 members (frogfarmer, pauld, Shaffer's1950, lumbersawyer, BC59, 1 invisible), 185 guests, and 5 robots.
Topics128,264
Posts1,058,358
Members48,485
#711665 01/14/2011 1:40 AM
RAK
Offline
Why is my mechanic having so much trouble with this rebuild? They tell me it's not as straight forward as it seems? It's a 3 speed in my '61 Half Ton.Any thoughts would be appreciated.Thanks,RAK
I've never heard of a BW WT266 transmission, your truck should have had the SM318 3 speed or a GM variant of the T89 3 speed (non overdrive). In either case, both transmissions are easy to overhaul. You may need to find a mechanic more knowlegable with older vehicles to overhaul it.
Bill Burmeister
I just recently found out from my parts supplier that the SM 318 is also refered to as a WT266 in their parts listings. There is also a WT265 which was used in the 64-65 Chevelle. They look very similar but none of the internal parts interchange. You can get parts from Anaheim Gear in Anaheim, CA for these transmissions, however they are pricy. I see these transmissions at swap meets all the time and they are relatively cheap.
Fred
RAK
Offline
Thanks for clearing that up. It's been rebuilt and my next trip to Oregon I'll drive it,that's where I have it parked.
