| | | Forums66 Topics128,165 Posts1,056,987 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | I would like to find an electric cut off saw which operates the small 3 inch discs, 3/8 arbor. I've seen many that are air operated, any suggestions.
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | I use my angle grinders more for cutting than I do for grinding. They use different wheels, though.
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
| | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | blanch53 what type of work are you wanting to do with it ?
| | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | The main use is to cut out some rusty metal on certain body panels, and inside the cab. This type of tool would allow for cutting close up to corners etc.
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I don't know how close of quarters you are working in, but you might like to use a Dremel Tool with cut off wheels. I am working on the interior cowl panels, and you get very precise cuts with the Dremel. I use tape as a cutting guide, plus you don't remove as much metal. Also use a full face protection mask as the Dremel wheels are a little soft and can shatter as they wear down. | | |
