2 members (tclederman, Peggy M),
84
Mod | | | Forums66 Topics128,175 Posts1,057,052 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 74 'Bolter | | 'Bolter Joined: May 2010 Posts: 74 | I don't know the name of the part that goes under the rear doors (between the wood and the bumper), but I was wondering whether it is the same for all TF panels and suburbans? Basically, it is the piece that goes across the back that you would step on when getting into the rear of the truck. If it is not the same for all years, what years would match a '58? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | same 55-59, 'burb or panel, doors or clamshell - called the rear door sill if your's needs work, you might as well start workin, any used one you find from a truck bad enough to part out will have hidden corrosion underneath where it mates to the rest, and they're not reproduced Bill | | | | | Joined: May 2010 Posts: 74 'Bolter | | 'Bolter Joined: May 2010 Posts: 74 | thanks. I know that most of them are bad, but just wanted to know so that I can keep my eyes open. Mine is not terrible, but I can always hope to run across one! I assume putting it in is a big job as well. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes, you could say it's work  Bill | | | | | Joined: Apr 2005 Posts: 2 New Guy | | New Guy Joined: Apr 2005 Posts: 2 | I have the part you are asking about that came out of a truck with clamshell doors I would be willing to part with pm me and I will send pics. Kevin
| | | | | Joined: May 2010 Posts: 74 'Bolter | | 'Bolter Joined: May 2010 Posts: 74 | | | |
