4 members (dt235sd, Erniegp, ndkid275, Otto Skorzeny), 55 guests, and 2 robots.
Topics128,054
Posts1,055,780
#709 03/03/2003 4:18 PM
Once again, I approach the fountain of knowlege for a drink. A local bargain trader has used Chevy 350 LT1 V8 small blocks for sale. Some have Aluminum heads ($650) and some have cast heads ($350). From the photos, they appear to be minus intake and flywheel. My question is: What does "LT1" mean? Is it 4 bolt main bearing caps, or does it have to do with other special feature? Do you think the asking price is reasonable? THANKS.
Regards,
Emil
#710 03/03/2003 4:57 PM
Emil; Not sure what LT1 stands for maybe chiphead does, but the price is only as good as motor, we've bought 350's from $25.00 (demo derby cars to $750.00 rebuilt short blocks)all said and done I've got about $1,800.00 in mine doing most of the work myself. I don't want Maws and me to break down in 59. popcorn
#711 03/03/2003 5:00 PM
I assume these engines are rebuildable cores. That's why I thought LT1 must mean something valuable to be asking that much. I will call them just for grins.
Regards,
Emil
#712 03/03/2003 5:19 PM
Apprentice
Apprentice
LT-1 350's first appeared in 1969 Corvettes and was available in the 70 1/2 Z-28 Camaro as well as Vettes.
Specs:
Displacement 350 ci
Bore and stroke 4.00 X 3.48
Horsepower 360/370 @ 6000
Compression 11.0 to 1
Chamber design Wedge
Carburetion 780 cfm Holley
Intake Aluminum high riser
Camshaft .458/.458-inch lift,317/346 deg duration
Lifters Solid
Valves,int/exh 2.02/1.60 inch
Pistons impact extruded aluminum
Rods forged steel
Crank forged steel
Exhaust Dual,cast iron headers
Ignition Single point,vacuum advance
Fuel required Premium
Heads had screw in studs
Four - bolt mains
70 GMC 7500 Tilt Cab
88 GMC G2500 Conversion
61 Massey Ferguson 35
74 John Deere 2130
81 Massey Ferguson 60 Backhoe
83 GMC C10
90 Navistar 4900
83 Honda CB1100F
73 Harley Davidson FXE
68 Chevrolet Impala SS
92 Chevrolet G1500
#713 03/03/2003 7:21 PM
Don't know for sure, but chevy prolly recycled the LT-1 designation from the late '60s when they came out with the new & improved model in the '90s.
The '60s LT-1 would be a nice engine to have if you could find one that wasn't blown to bits. It follows most of the typical rules of a performance 350.
The '90s LT-1 was a reverse cooled, computer controlled engine. It uses serpentine belts, a special MPFI intake, special electrical system & all those sensors & powertrain control computers. It'll make great power if you can find all the electrical & electronic gizmos to go with it.
I could be wrong, but I believe that these motors are related to the late '90s & up LS-1 engines used in F-bodies & vettes, that had a carbon-fiber intake, coil-on-plug ignition, reverse flow cooling system, etc.
Basically the '90s LT-1 & LS-1 350s are related to the older 350s in displacement alone. Not many parts will interchange, including the accessories, electrical and cooling systems.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#714 03/04/2003 2:59 AM
A friend of mine had one in a 94 caprice cop car,a good running motor but has alot goofy stuff on it like a behind the waterpump front distributor,a cam driven waterpump and more. I think they can be converted to normal but might be better to find a regular 350
#715 03/04/2003 11:52 PM
Lots of great info, I printed that article from Automotive Rebuilder and will be reading it a few times. The fact about the later models needing the ancillary parts and computer controls to work right will kill it for me. I didn't see a distributor in the photo either ($500-$600 egad!) or water pump or pulleys, etc. Thanks all for helping me avoid a costly blunder. I will be studying a bit longer on this.
Regards,
Emil
#716 03/06/2003 8:02 AM
while the info provided was accurate, and interesting, it tells a part of yer question. general motors uses these numbers to designate a series of engines. big blocks are l-88 (old 427's) ls-6 (454) lt-1 (performance 350). etc. there are several designations of engines. oh yeah---old 350's really don't like new 350's. unless you are racing the numbers don't mean much if you are staying close to stock. a buddy of mine bought a new vette and was bragging about how fast it goes. i ask him if he's ever raced it---he asks me if i'm crazy. i ask him if he's ever had it over a hundred---he asks me if i realize just how expensive the car is. i look at him and smile and tell him how fast my junk pickup goes--and tell him i know it for a fact, cause i drove it that fast. then i ask him if he would have been better off with a v-6 and saved his money. he ain't never gonna use the power, so why have it. the point? well, if you ain't racin' how about taking a good engine and rebuilding it to reliable? add a few improvements to the intake, exhaust, and ignition system to make a solid reliable street ride. throw away the original cam. it makes a great ashtray stand. the lt-1 is a good engine, and i have run a few, but not necessary in a normal ride. save yer bucks cool
