2 members (Gray_Ghost, Joe W),
211
Mod | | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 19 | I have a 60 Chevy Suburban K10 six cylinder and I'm trying to figure out how the factory installed the V8s in the K10 frame. If any of you could advise it will be a great help. Thanks,Jon | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Seems like they used a U-shaped bracket on the front of the engine. | | | | | Joined: Oct 2010 Posts: 24 New Guy | | New Guy Joined: Oct 2010 Posts: 24 | Yep my 60 Apache-10 has a ushaped bracket that bolts to the front of the block and has one bolt down on the bottom. Then my bellhousing has side mounts. I think my bellhousing came from a 55 chev. car. | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | torker got any pics of that setup | | | | | Joined: May 2010 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 19 | I see that U shaped bracket on regular trucks but on a 4x4 theres no crossmember to set it on, Thats my dilema.The crossmember thats on my trucks is a bent 3 inch round pipe that dips below the oil pan. Seems to far forward to get the V8 to mount. Any ideas ?
Jon Krogh | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | i asked to because on my 62 k-20 it at 1 time had a 283 and i dont know either how it was mounted | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | It was more than likely side mounted perhaps similar to the 63-66 years. they had side perches that were on either side within the frame rails. 2 wheel drives all had that large frt crossmember for the frt end. 4 x 4's don't have that so have to mount differently. other than that if you I6 mounted on that 3" round pipe ,your 283 may mount there as well, utilizing the same frt mounting that was used on the 265 engs in 55-56 cars and I believe l/duty trucks up to 59. they used those 2 vertical 3/8 threaded holes on either side of the frt crank pulley ron | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | Yep my 60 Apache-10 has a ushaped bracket that bolts to the front of the block and has one bolt down on the bottom. Then my bellhousing has side mounts. I think my bellhousing came from a 55 chev. car. that bellhousing could be a 60 in a 4 x 4. don't know whether or not that they used the hydraulic clutch in a 4 x 4 as they didn't have the same frame problem as a 2 wh/dr in 60-62. perhaps someone can correct this? ron | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | They used the hydraulic clutch in 60-62 | | | | | Joined: May 2010 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 19 | I have a 60+61 K10s, all have hydraulic clutchs. I just looked up the part numbers in my Chevrolet parts books and it does state a Different " Support Assembly, Front part number 3771503" for 4x4 only V8 trucks and 3770820 for six cylinder. Problem is it does show what it looks like
| | | | | Joined: May 2010 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 19 | My 68 parts book states the side mount for K10 as 1963-1966. Anyone have a factory V8 K10-K20 ?? Joe do you have pictures of the frame mount in your 62 K20 ? | | | | | Joined: May 2010 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 19 | i asked to because on my 62 k-20 it at 1 time had a 283 and i dont know either how it was mounted Joe can you look and see if yours has the round front cross member and if the mounting pad on it is in front or behind the cross member. My 6 cylinder cross member has the mounting pad in front. [IMG] http://i270.photobucket.com/albums/jj87/jon67427/60-62%20K10/Picture005.jpg[/IMG]
| | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | | | | | | Joined: May 2010 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 19 | Look at the picture link Joe you can see how the engine is mouted with the pad in front for the six, wondering since you said yours was a 283 if the pad is reversed ? or on the back side of that tube. This might be the difference in these crossmembers from V8 to six | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | GMC's used that same style crossmember ron | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | thats the same as my 60 k-20, the v8 must of had that mount reversed like you said. i would like to see a pic of 1 to make sure. | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | the tube is long gone on the 62 so i dont know if it was on the front or rear of it
| | | | | Joined: May 2010 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 19 | GMC's used that same style crossmember ron Correct but if its a V6 it is not used to mount the engine .The V6 was side mounted to the frame. Or at least my original 62 K10 GMC Sub is like that. JK | | | | | Joined: May 2010 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 19 | thats the same as my 60 k-20, the v8 must of had that mount reversed like you said. i would like to see a pic of 1 to make sure. Me to, want to make sure I do it right the first time. I measured from the Bellhousing forward and its right where it should be. JK | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | I need the tube and horseshoe for mine ,they were off the truck when i bought it | | | | | Joined: Oct 2010 Posts: 24 New Guy | | New Guy Joined: Oct 2010 Posts: 24 | I don't have a pic right now. 0 deg. and I have to see if my car will start to go to town. Sounds like the 4x4 is different - mine is 2wd but I will try to get a pic unless someone beats me to it. | | | | | Joined: May 2010 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 19 | It has to be a 4x4, 2 wd is completely different but thank you | | |
