| | | Forums66 Topics128,108 Posts1,056,565 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 1995 Posts: 5,727 24601 | | 24601 Joined: Nov 1995 Posts: 5,727 | A couple of questions for anyone who knows their antique (pre-WWII) wrenches (I seem to have the wrenches, but I am not familiar with these terms or what the wrenches were designed for):
1. Tool Post Wrench?
2. Textile Pattern Wrench?
3. Slugging Wrench?
Thanks for any help.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | vintage tool descriptions and pics, at least the first 2 are there [1/2-3/4 down] .... I think the slugger is an impact wrench [hand or hammer] for tight spaces, still common from tool suppliers, apparently used on turbines Bill | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | The Tool Post wrench has 1 or more small 1/4" or 5/16" open ends or socket style ends for use on a lathe tool post. The tool holder has bolts with a small square head on it. The slugging wrench looks like half of a very heavy box end wrench and has a heavy square opposite end which is struck (or "slugged") with a hammer. Used in heavy mechanical work. The textile pattern wrench (I'm guessing here) would be used on a loom for setup work? Examples of the Tool Post and Textile Pattern wrenches here: J.H. Williams tools Slugging Wrench here: Proto Slugging Wrenches
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | most of the tool post wrenches i have have a one square box end so they can stay on the bolt when you let go of it. i have used a few box end wrenches as slugger wrenches a time or two!  | | | | | Joined: Nov 1995 Posts: 5,727 24601 | | 24601 Joined: Nov 1995 Posts: 5,727 | Thanks gents -- The Alloy Artifacts site was great and where I started before I posted the question. That's where I figured out what the wrenches were. The site, though, assumes you know what a Tool Post Wrench or a Textile Pattern Wrench is because it doesn't go into any detail beyond just the nomenclature.
These wrenches I have are J.H. Williams tools. And early ones, too, judging by the patent stamps.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | The slugging wrench is called a hammer wrench where I worked. Used to tighten very large nuts on 1 to 1 and 1/2 inch size bolts. Pipeline valves etc. If you encounter a combination wrench that has a pointed end it's a spud wrench. Used to align flanges that bolt together on piping systems. | | | | | Joined: Nov 1995 Posts: 5,727 24601 | | 24601 Joined: Nov 1995 Posts: 5,727 | If you encounter a combination wrench that has a pointed end it's a spud wrench. Used to align flanges that bolt together on piping systems. Cool! I'd seen those wrenches, too, and wondered what they were designed for. Now I know. Thanks! John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Hey John. If any of your tools have a U.S. Patent number stamped on them, you can do a U.S. Patent search, through the U.S. Patents & Trademarks office. I learned this, through the patent process and it may help you discover the date, used & description of your tools, as well as, the original manufacturer and origin. I hope this information is helpful and good luck. | | | | | Joined: Nov 1995 Posts: 5,727 24601 | | 24601 Joined: Nov 1995 Posts: 5,727 | Tony -- Thanks. I bet that will be very helpful! It seems there's a couple of us researching old wrenches at the moment.
Regards, John
