0 members (), 116 guests, and 2 robots.
Topics128,105
Posts1,056,541
Members48,448
24601
A couple of questions for anyone who knows their antique (pre-WWII) wrenches (I seem to have the wrenches, but I am not familiar with these terms or what the wrenches were designed for):
1. Tool Post Wrench?
2. Textile Pattern Wrench?
3. Slugging Wrench?
Thanks for any help.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
vintage tool descriptions and pics, at least the first 2 are there [1/2-3/4 down] .... I think the slugger is an impact wrench [hand or hammer] for tight spaces, still common from tool suppliers, apparently used on turbines
The Tool Post wrench has 1 or more small 1/4" or 5/16" open ends or socket style ends for use on a lathe tool post. The tool holder has bolts with a small square head on it.
The slugging wrench looks like half of a very heavy box end wrench and has a heavy square opposite end which is struck (or "slugged") with a hammer. Used in heavy mechanical work.
The textile pattern wrench (I'm guessing here) would be used on a loom for setup work?
Examples of the Tool Post and Textile Pattern wrenches here:
J.H. Williams tools
Slugging Wrench here:
Proto Slugging Wrenches
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
most of the tool post wrenches i have have a one square box end so they can stay on the bolt when you let go of it. i have used a few box end wrenches as slugger wrenches a time or two! eeeek
24601
Thanks gents -- The Alloy Artifacts site was great and where I started before I posted the question. That's where I figured out what the wrenches were. The site, though, assumes you know what a Tool Post Wrench or a Textile Pattern Wrench is because it doesn't go into any detail beyond just the nomenclature.
These wrenches I have are J.H. Williams tools. And early ones, too, judging by the patent stamps.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
The slugging wrench is called a hammer wrench where I worked.
Used to tighten very large nuts on 1 to 1 and 1/2 inch size bolts. Pipeline valves etc.
If you encounter a combination wrench that has a pointed end it's a spud wrench. Used to align flanges that bolt together on piping systems.
24601
Cool! I'd seen those wrenches, too, and wondered what they were designed for. Now I know. Thanks!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Hey John. If any of your tools have a U.S. Patent number stamped on them, you can do a U.S. Patent search, through the U.S. Patents & Trademarks office. I learned this, through the patent process and it may help you discover the date, used & description of your tools, as well as, the original manufacturer and origin. I hope this information is helpful and good luck.
24601
Tony -- Thanks. I bet that will be very helpful! It seems there's a couple of us researching old wrenches at the moment.
Regards,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Moderated by  MNSmith
