6 members (JW51, fonz8261, baldeagle, obs2kl, Bill Hanlon, 1 invisible), 59 guests, and 7 robots.
Topics128,021
Posts1,055,346
Members48,420
#710236 01/09/2011 4:32 AM
Hi,
I am putting a later engine in my '36 1 1/2 ton and based on the casting # 3837004 it is a 1955-57 T56X 235-261.
What does the T56X designation stand for and how do I find out if it is a 235 or 261 ?
David
dmart #710241 01/09/2011 4:59 AM
T56X, Tonanwanda plant, 1956, 235 3100/3200 w/manual transmission 140 hp.
Bill Burmeister
LONGBOX55 #710368 01/09/2011 7:01 PM
David,
Block casting 3837004 is a 235 only.
One of the best ones out there.
T56X is here...
http://chevy.oldcarmanualproject.com/chevyresto/56070.htm
Your engine specs.....
http://chevy.oldcarmanualproject.com/chevyresto/56152.htm
-Tom
1950 Chevy 3100 w/ 1956 235
Oilrag #710381 01/09/2011 8:23 PM
Bill, Tom,
Thank you both for the info.
Didn't really know what I was looking for when I picked it up and had a bit of luck. Just changing the ring and pinion and hopefully will end up with a decent, local, daily driver.
Thanks again.
