0 members (), 102 guests, and 3 robots.
Topics128,186
Posts1,057,319
Members48,469
#710045 01/08/2011 4:49 PM
Where is the window washer bottle located on a 66. My assembly manual shows it on the firewall but it wont fit there and there are no holes to mount it.
My 65 is on the drivers side inner fender close to the master cylinder.
Mine is in a windex bottle in my hand. smile
glos55
The correct location is on the driver side of the radiator support, just above the voltage regulator & horn relay, as stated above. There are two holes, in this location, to receive the stand-off brace of the washer fluid bottle bracket.
Again, on a 66 Burb, was this a bottle or a bag? I see the aftermarket parts show a bag replacement. If it was the bottle, does any one supply these?
Thank you
Definitely a bottle. You should be able to get one on ebay, LMC truck or even on the parts wanted board.
