2 members (delky, dt235sd), 43 guests, and 3 robots.
Topics128,179
Posts1,057,157
Members48,465
Hi all, I am selling the front axel from my '54 1/2 ton panel. A potential buyer wants to know if it will work on a 3/4 ton truck. I don't know but know some of you do. Thanks as usual
All the best, Ted
Yes, it will bolt up to a 3/4 ton.
(Advance Design series) It was discussed here a while back.
Steve
'49 3800
'52 3600
'57 3100
What does he intend to accomplish?
Can the 1/2-ton axle be installed on a 3/4? -- Yes. Can he continue to use his 8-lug hubs and brakes? -- No.
If his goal is to convert to 6-lug, or to use a 1/2-ton disk brake kit, then its a good swap.
