1 members (dt235sd),
307
7
Mod | | | Forums66 Topics128,159 Posts1,057,039 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 16 New Guy | | New Guy Joined: Dec 2010 Posts: 16 | I am considering putting a 1988-1996 rear end from an E350 in my 1950 3/4 ton GMC to lower the gear ratio. It appears the track witdth on the E350 is around 67 inches and my truck is around 63 inches. Does anyone have experience with this rear end in a similar truck? Thank-you | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Well, your measurements tell you it probably won't place the original wheels under the fenders where they fit... Are wheels available with the necessary 2" different back spacing? Are you OK with using different wheels front and rear? Another option is a GM 14 bolt rear axle, they come about 63" wide in some applications. https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=686209&page=1Grigg | | | | | Joined: Dec 2010 Posts: 16 New Guy | | New Guy Joined: Dec 2010 Posts: 16 | Thanks for the tip. I am going to the junk yard today to measure an E350 just to make sure. I would like to stay with the 8 lug 6.5 inch bolt pattern if possible. Thank, | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | An e-350 is going to be way too wide for that truck. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The rearend is a Dana 60, try checking under Dodge 3/4 and 1 ton vans. That one will work just fine.
Bill Burmeister | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Erin, Check Dodge 3/4 and one ton vans with full floating Dana 60's. They are usually about 65" wide at the wheel mounting surface.
