7 members (Hanks custodian, TUTS 59, Guitplayer, Gdads51, Steelonsteel, Mike Burns, 1 invisible), 84 guests, and 3 robots.
Topics128,066
Posts1,055,871
Members48,428
#709554 01/07/2011 12:12 AM
The hood windlace (seal between hood and cowl) needs replacing on my '41 and I'm considering what to use as a replacement. The original is a fabric strip with a wire inside. The original type is available in parts catalogs, as well as a rubber type that was apparently used on the '46's. I'm not a stickler for sticking with original and want to use what would work best. What have other people found to be the best thing to use?
My toys:
'41 Chevy Model AL 3/4 Ton
'40 Chevy Model KD 3/4 Ton
Hinomoto 209N Tractor/Backhoe
Norwood LM2000 Sawmill
PJ 16' Trailer
and a Brand New Shop!
Be what you is, not what you ain't, 'cause when you is what you ain't, then you ain't what you is.
Ex Hall Monitor
Ex Hall Monitor
It's less a "seal" and more to keep the painted surfaces from rubbing. My personal preference is to use the original type material. That's what I did on my '38.
I took the easy way out & used a self adhesive foam weatherstrip product ...about 3/4" wide x 3/16" thick.
1940 Chevy KC 1/2-Ton
