| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 83 | The hood windlace (seal between hood and cowl) needs replacing on my '41 and I'm considering what to use as a replacement. The original is a fabric strip with a wire inside. The original type is available in parts catalogs, as well as a rubber type that was apparently used on the '46's. I'm not a stickler for sticking with original and want to use what would work best. What have other people found to be the best thing to use? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | It's less a "seal" and more to keep the painted surfaces from rubbing. My personal preference is to use the original type material. That's what I did on my '38.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I took the easy way out & used a self adhesive foam weatherstrip product ...about 3/4" wide x 3/16" thick. | | |
