| | | Forums66 Topics128,060 Posts1,055,839 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#70916 12/31/2006 10:41 PM | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Well I am coming along with the process of fitting disk brakes on the 3600. Not as easy as I had hoped... I have the the spindle diameter, bearings, and spacers figured out. I am now working on the bracket. The first attempt had the caliper too low. I am working on a new bracket to move the caliper up so the tie rod end will not hit the caliper. http://i39.photobucket.com/albums/e187/Sawmill/108-0887_IMG.jpg Once the bracket is done, I think it might be ready to try out! Rick | | |
#70917 01/01/2007 1:03 AM | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | That's looking good Rick! | | |
#70918 01/02/2007 11:13 PM | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Rick have you posted previously about this? I have a few questions: What calipers are you using? What rotors? What wheel diameter, width and backset? Did you have to machine the spindles or anything else? Do you have other pictures? Would you be willing to post a Tech Article on this site when done so others can learn from your experience? Thanks!! Edit: Sorry - I did a "view all posts" for you and I think I can follow the chain of events. Thanks and good luck. Frank.
Professional Novice
#70919 01/03/2007 5:53 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Its hard to tell relationships in a photo, but I'm wondering if the brake flex line will hit the axle when turned all the way? Have you checked that?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
