9 members (warlock, Otto Skorzeny, 55shaker, k2handyman, RoadsScholar, Ponchogl, 5 Window 9434, 6inarow, 1 invisible), 97 guests, and 2 robots.
Topics128,048
Posts1,055,626
#70916 12/31/2006 10:41 PM
Well I am coming along with the process of fitting disk brakes on the 3600. Not as easy as I had hoped... I have the the spindle diameter, bearings, and spacers figured out. I am now working on the bracket. The first attempt had the caliper too low. I am working on a new bracket to move the caliper up so the tie rod end will not hit the caliper.
http://i39.photobucket.com/albums/e187/Sawmill/108-0887_IMG.jpg
Once the bracket is done, I think it might be ready to try out!
Rick
#70917 01/01/2007 1:03 AM
That's looking good Rick!
#70918 01/02/2007 11:13 PM
Rick have you posted previously about this? I have a few questions: What calipers are you using? What rotors? What wheel diameter, width and backset? Did you have to machine the spindles or anything else? Do you have other pictures? Would you be willing to post a Tech Article on this site when done so others can learn from your experience? Thanks!! smile
Edit: Sorry - I did a "view all posts" for you and I think I can follow the chain of events. Thanks and good luck. Frank.
Professional Novice
#70919 01/03/2007 5:53 AM
Its hard to tell relationships in a photo, but I'm wondering if the brake flex line will hit the axle when turned all the way? Have you checked that?
