5 members (Hanks custodian, mick53, moparguy, CATMAN, joe apple), 86 guests, and 2 robots.
Topics128,151
Posts1,056,989
Members48,460
#708731 01/04/2011 7:16 AM
Do you have to pull the engine, to fix a rear main seal leak? believe thats what is happening, my clutch is gitting oil soaked. Dont think it's from my trans, looks to thin. No visible leaks from my engine on the out side ? It's a 292 straight six.
Not clear from your post or your gallery write up, but I'm assuming that your truck has been updated with a 292 GMC engine?
The stock '47 would have been a 235, basicly the same engine as the 216 of that year.
And yes, if you can get the pan off of the COE you can replace the rear main seal. It works as long as the rear main bearing is adjusted correctly. If there is to much clearance in the rear main your still going to have a leak at the seal after a few thousand miles when the seal gets hammered in.
DG
Denny G
Sandwich, IL
I would heed Denny's advice or hint. Ask me how I know!
1951 1 Ton Completed
The seal should be easy to replace.
A 292 will have a neoprene lip seal. They can take a little more crank movement from worn bearings than a rope seal.
My Blog
Yes, previous owner put in the 292. Thanks much for the reply's, I will give it a go. Just did'nt want to pull the motor if I did not have too, thanks again.
