6 members (Gray_Ghost, Gdads51, Phak1, Tiny, dunfire, John Dlugos), 73 guests, and 8 robots.
Topics128,187
Posts1,057,211
Members48,465
Im looking to replace the sael that goes on top of the fender and seals the hood.
Can someone please tell me what this is called...LOL
I have looked everywhere and cant seem to find it
LMC catalog should have that in picture format...if you clarify I will look at mine..are you looking for 2 separate seals? or are you looking for one...is it the seal between the front fender and the side cowls? or are you looking for a seal on the hood? got a pic of the area?
*UNDER CONSTRUCTION*
1953 Chevrolet 3100 1/2 ton-previously abandoned resto.
My Project Bolt
I hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
Thanks Silverado
Im looking for the 2 sepepate seals. The seal is attatched to the top of the fender/cowl and when you close the hood it seals it.
the origanal on mine now looks like some sort of foam material.
Its the long seal along each side of the hood....not the seal at the rear of the hood that goes to the cowl.
I looked on lmc at the picture and still dont see it..LOL
Maybe im just a lil slow or something tonight.LOL
Leo Offline
Moderator
Moderator
Mine doesn't have a seal there, not on the sides of the hood. What does it need to seal?
Mine doesn't have a seal as you describe either. There are bumpers located in that area. So I'm wondering if someone uses a generic seal to replace old worn out bumpers?
1951 Chevy 1-Ton Panel
Pictures of the restoration on Photobucket
RIP good friend.
Manley,
My guess is that is not original. Sounds to me like a standard hardware store special. foam weatherstripping with one sticky side. mind you this is without seeing it.
My Project Bolt
Ive bever seen a seal along the area youre talking about. Theres 3 or 4 bumpers for that area(top fender edge to lower hood edge),,or the hood/to cowl seal,which you say it isnt.
Or theres the fender welt,,where fender meets the body, just in front of the door.
As Ned mentioned,Perhaps someone added a rubber seal in that area?? To stop a rattle.
Thanks Guys, you all are great and i appreciate the help
I looked everywhere and couldnt find it so i believe you all are right about someone adding aftermarket foam/seal to stop squeeking or rattling.
And the rubber bumpers arent there,so it only makes sense now that someone added the foam to stop the rattle
Thanks guys i will be ordering the hood bumpers
top fender edge to lower hood edge is where this foam was put....so i agree someone used the foam to replace the worn out bumpers
glad to help, you have any pix of your truck online anywhere?
My Project Bolt
