0 members (), 38 guests, and 4 robots.
Topics128,089
Posts1,056,004
Members48,430
#707785 01/01/2011 12:25 AM
What is the best method and process for painting wheels after sandblasting? What type primer and paint do you recommend?
I primed mine with self eching then 2k and then a top coat of paint with colorand used por 15 on the inside
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
After sandblasting I used metal prep to clean off the dust,oil and other contaminants. For primer I used Rustoleum Industrial in a Gallon can. I let the primer dry well and sanded it lightly then painted with Rustoleum Industrial gloss black.After all this work I took them to have the tires installed and they scuffed the wheels up for me ! Next time I would like to try powder coating the wheels.
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
Ever notice one of the first places you see rust on wheels is the crevice where the center joins up with the rim because the sprayed paint doesn't get in the crack.
Before I spray my wheels I thin the paint a little and paint that crevice with a brush letting it run into the crack, where sprayed paint can't get to very well. Look for drips out the back side and wipe off.
If done right with a small brush any brush marks left will be covered when you top coat the wheel.
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
I like the idea of letting the paint run in the crack. Will put that in my bag of tricks........Thanks
Dan
