| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | What is the best method and process for painting wheels after sandblasting? What type primer and paint do you recommend? | | | | | Joined: Jan 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 126 | | | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | I primed mine with self eching then 2k and then a top coat of paint with colorand used por 15 on the inside
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | After sandblasting I used metal prep to clean off the dust,oil and other contaminants. For primer I used Rustoleum Industrial in a Gallon can. I let the primer dry well and sanded it lightly then painted with Rustoleum Industrial gloss black.After all this work I took them to have the tires installed and they scuffed the wheels up for me ! Next time I would like to try powder coating the wheels. | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | Ever notice one of the first places you see rust on wheels is the crevice where the center joins up with the rim because the sprayed paint doesn't get in the crack.
Before I spray my wheels I thin the paint a little and paint that crevice with a brush letting it run into the crack, where sprayed paint can't get to very well. Look for drips out the back side and wipe off.
If done right with a small brush any brush marks left will be covered when you top coat the wheel.
Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I like the idea of letting the paint run in the crack. Will put that in my bag of tricks........Thanks Dan | | |
