| | | Forums66 Topics128,023 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 66 | I want to redo the the face on my 35 truck speedo,amp.oil.gas.etc I got a new stick on kit what do I need to do this myself do all the needels just pull off someone told me the speedo does but not sure on the others has anyone done this? I have not started yet | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It took some time to decipher your question because of your lack of punctuation. Re-facing gauges is tedious work. If you are in too much of a hurry to type correctly I doubt you have the patience to do a good job on the faces.
The speedometer needle will pull off the shaft. The other needles will not. You have to carefully slip the face decal over the needle and get the decal lined up properly before setting it on the surface.
Be sure you get the face clean and lint free before placing the decals. Microscopic imperfections become big bumps when the new face is installed.
The odometer wheels must have the numbers installed in the same place as the original numbers to properly function. Before cleaning them, make a scribe mark on the side of the wheel exactly between the 0 and 9. After they are cleaned the numbers will be gone and the scribe mark will be all you have to go by.
As I said, it is tedious work. But the pretty new faces will look nice. | | | | | Joined: Mar 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 66 | thanks for the information sorry about how I posted , it does seem hard to understand | | | | | Joined: Mar 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 66 | O GABSTER I can see by your profile that your one of the better people out here. y You must feel good about yourself.Not everybody is perfect, I see many people have trouble with different things, but I keep them to myself so be a little kinder when you post or just pass it by and let someone else respond HAVE A NICE DAY | | | | | Joined: Mar 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 66 | THANKS DADS50, that will help,even if its not the same year.good to hear posative feedback | | |
