4 members (Lugnutz, Peggy M, Oswald, baldeagle), 104 guests, and 5 robots.
Topics128,014
Posts1,055,328
Members48,419
#708099 01/02/2011 5:16 AM
With the bit of searching I've done, I understand the cab related parts interchange between the pickups and big bolts, yet the front clip (fenders/hood) is different. Wouldn't the headlights be the same though, along with the grille? What about the trim along the hood sides?
Thanks.
46 Chevy 1 1/2 ton
Hi oakandiron,
Correct, the headlights are the same. The fenders are what is different. On a big bolt, the fenders are much bigger, to accommodate the larger wheels & tires. Also the the lower splash pan below the grille is different and the radiator support as well.
The cab, hood, Grille & lights are the same for both a pickup & a big bolt.
Excellent, thanks JeffL.
46 Chevy 1 1/2 ton
One other point: C O E head light bullets are the same on each side, conventional trucks have a right and left.
