5 members (HandyAndy, 2-Ton, 78buckshot, TUTS 59, Wally / Montana), 91 guests, and 2 robots.
Topics128,060
Posts1,055,835
#705072 12/20/2010 8:56 PM
Changing the 235 engine in my '55 1st series to a 235 engine from a '60. The '55 is 6 volt and the '60 is 12 volt. I am changing the '60 235 engine bellhousing to use the '55 235 engine bellhousing. I have two choices. I can keep the truck 6 volt using the flywheel, starter with floor starter or I can use the '60 flywheel, starter and convert the truck to 12 volt. If I go with the 12 volt, I'll need to add a push button for the starter. There are some advantages in having a 12 volt system and some advantages in keeping the 6 volt system. Looking for some advise.
look at things seperately, you can keep everything 6V by just using a 6V coil on the later engine along with the 6V flywheel and starter and the 6V gen/reg - you can change to 12V and still keep the 6V starter or you can find a 12V starter from 55-59 that still uses the foot stomp .... the main consideration is really the gauges and accessories when going to 12V
Ex Hall Monitor
Ex Hall Monitor
If everything is in good condition and well maintained there is little reason to change to 12v. My 2cents.
Tiny #705147 12/21/2010 2:29 AM
I am like you Nels. Trying to decide whether my 48 should stay 6 volt or change over to 12 volt. Sounds like your 12 volt set up is key start. I would like that since I care to go with a key start.
Keep us informed on your decision.
Dennis
I like the 12 volt system.I kept the foot starter still 6 volt it will work ,just don't stay on the starter when cranking.Later when the starter needs rebuilt I will convert it to 12 volt.I just thought the rest of the world use's 12volt it's harder to find 6 volt parts at auto part stores. Also I use a 12 volt generator that is rebuilt .
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
Apprentice
Apprentice
i run my 54 daily 12v conv halogen headlites all been good 4
3yrs. still running 6v starter just never run it over 10 sec. & 1 min. let cool b4 cranking again
jwart #708153 01/02/2011 3:27 PM
If you use 6 V horns on 12 volts, you can wake up the entire neighbourhood! The horns really deliver on 12 volts.
1951 1 Ton Completed
