1 members (classicchevs),
101
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | My donut gasket keeps burning up and I am tired of replacing it. I buy the original ones from auto zone is there a metal gasket the will work that won't burn up. And do those original ones have asbestos in them. I have breathed the fumes from them when they burn up it comes in the cab a little. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is a metal one available. I have the GM part # at the shop. There needs to be a sleeve inside the donut. Get a piece of ex. pipe that will fit the recess in the manifold. cut off a short piece of it just long enough to fit down the end of the taper in the ex. pipe. You can use the original type with this as it will keep the fire off the donut. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | I am not quit understanding this part but it sounds like the answer for me.
(Get a piece of ex. pipe that will fit the recess in the manifold. cut off a short piece of it just long enough to fit down the end of the taper in the ex. pipe.)
Will a muffler shop have a pipe? (the ex. pipe) that goes in the recess of the manifold And what fits down the end of the taper in the ex. pipe
Amusing that ex pipe means extra pipe
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Maybe this picture will help. I had a local muffler shop make. Approx 40 beans for the entire pipe. Have fun and good luck Dan
| | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Here is an example of a donut sleeve (for a Corvette). Some exhaust pipes have a conical flange welded to the pipe about a half-inch down from the upper end which supports the bottom of the donut that then slips over the pipe. This also works if you are starting from scratch with the system and can find or fabricate the parts. I was looking for a photo of such a setup that I welded up a few years ago when I fabricated the exhaust system for my street rod. The exhaust pipe upper tips were cut from a 1978 Chevrolet V-8 (I recall) and I used2-bolt flanges from Tom Langdon to bolt to my headers. I just saw Dan's photo; similar to what I made. Hoyt
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | I had a local muffler shop make. Approx 40 beans for the entire pipe. Dan my muffler guy made that up for me for my 6100. he calls the short piece the fire pipe. he also have me longer studs with brass nuts. i had to use star washers to keep the nuts from working loose. he said in another 50 years i wouldnt be snapping the stud in half when i have to removes it. we'll see  | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Mike, I started using brass nuts over 50 years ago and I can assure you that none of them lasted 50 years. The stud might not break, but the nuts round off and won't thread off which isn't the end of the world with a 6 cy, but its a real pain on a Y-Block. We use stainless on our trucks and I think that would be the way to go on my jalopies too. | | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | Thanks for the help it took a while to sink in but the sleeve keeps the exhaust off of the donut that is the fix. | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Rather than using brass nuts, I use Naval bronze. They are stronger and have about the same corrosion resistance. Bronze is better at resisting corrosion from salt water. I picked mine up at a marine supply.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
