3 members (1955 1 Series, Jon G, Hotrod Lincoln), 107 guests, and 2 robots.
Topics128,122
Posts1,056,332
Members48,439
engine is buried in a shed at this time, only numbers i was able to reveal is "F0215JC". i know there are other numbers but i need to spend more time uncovering the engine. The little looking around i did makes me think this is a 54-58 235. any info would be greatly appriciated!
It's a '58-'62 235, built at the Flint plant, truck application w/manual transmission. To peg the year, there's a casting date on the passenger side of the block to the rear, next to where the starter would sit.
Bill Burmeister
My guess is that you will not be able to tell the year from that code.
F0215JC
F = Flint, MI plant
02 = month = February
15 = day = 15th of the month
JC = 4000 series truck
An engine serial number (engine ID) with that format started being used in 1957.
thanks alot! i bought this truck in 1993 on my 14th birthday and was told from the 2nd owner that it was the original motor and it was a "low pressure 235" but in the recent years i questioned that.
so would this motor of come from a 3/4 ton then? (4000 series)?
I think that a 4000 series would have been a 1.5 ton
My guides do show that engine being used in 1/2 though 1 ton as well. 4000 would be 1.5 ton.
Bill Burmeister
Yes, your motor was also used in the 3/4 ton,
and it had the Heavy-Duty Clutch, 11" Diameter.
What size truck do you have?
-Tom
1950 Chevy 3100 w/ 1956 235
its a 1951 5 window half ton deluxe cab. well it was in 1993 when i took it apart. just now settled down and have a house and a garage to start restoring it. Right now im working on re attaching the brackets to the frame after i had it all powder coated and also installing disc brakes on the stock axle.
i was just thinking about the gauges i had in the truck before i tore her down. the oil pressure gauge was 0 to 60 lbs. Now if the truck came with a 216 originally, wouldnt the gauge be only up to 30 lbs?
In 51 all Chevs 216 or 235 would be low pressure. I suspect someone installed a GMC gauge at the same time as the 235.
My Blog
hmmm thats interesting. thank you for the info!
