1 members (Jon G),
136
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,124 Posts1,056,334 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | engine is buried in a shed at this time, only numbers i was able to reveal is "F0215JC". i know there are other numbers but i need to spend more time uncovering the engine. The little looking around i did makes me think this is a 54-58 235. any info would be greatly appriciated! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It's a '58-'62 235, built at the Flint plant, truck application w/manual transmission. To peg the year, there's a casting date on the passenger side of the block to the rear, next to where the starter would sit.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | My guess is that you will not be able to tell the year from that code. F0215JC F = Flint, MI plant 02 = month = February 15 = day = 15th of the month JC = 4000 series truck An engine serial number (engine ID) with that format started being used in 1957. | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | thanks alot! i bought this truck in 1993 on my 14th birthday and was told from the 2nd owner that it was the original motor and it was a "low pressure 235" but in the recent years i questioned that. | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | so would this motor of come from a 3/4 ton then? (4000 series)? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think that a 4000 series would have been a 1.5 ton
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | My guides do show that engine being used in 1/2 though 1 ton as well. 4000 would be 1.5 ton.
Bill Burmeister | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Yes, your motor was also used in the 3/4 ton, and it had the Heavy-Duty Clutch, 11" Diameter.
What size truck do you have?
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | its a 1951 5 window half ton deluxe cab. well it was in 1993 when i took it apart. just now settled down and have a house and a garage to start restoring it. Right now im working on re attaching the brackets to the frame after i had it all powder coated and also installing disc brakes on the stock axle. | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | i was just thinking about the gauges i had in the truck before i tore her down. the oil pressure gauge was 0 to 60 lbs. Now if the truck came with a 216 originally, wouldnt the gauge be only up to 30 lbs? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | In 51 all Chevs 216 or 235 would be low pressure. I suspect someone installed a GMC gauge at the same time as the 235.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2010 Posts: 114 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 114 | hmmm thats interesting. thank you for the info! | | |
