1 members (Hotrod Lincoln), 97 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#707706 12/31/2010 6:56 PM
I was trying to figure out what rear axle was in my one ton dually. I first thought it was an HO72 but the bolt pattern is different than a HO52 that I have and I thought they were the same I might be wrong though. Also there is no thrust pad that I thought all the Eaton HOs had. Thanks
Pics of axle
3B Offline
Hy spectra, that is a Timken rear axle. Are there any numbers on the tag? Does it take the same wheels as the front axle? I'll look in my books and see what I can find.
3B #707754 12/31/2010 10:08 PM
3B Offline
Hy spectra, can you tell us your series designation? A 57 250 series with a V8, lists a Timken B100 as standard equipment, could that be it?
3B #707759 12/31/2010 10:32 PM
3B thanks for the replies it is a V8 250 series the numbers on the axle are B101HX1 and 176497 it has a 5.14 ratio. and yes both front and rear are the same eight bolt. Do you know if parts are available like seals and such? Thanks
3B Offline
Hy spectra, according to my Bower/BCA catalog the wheel seal is National 2081, and the pinion seal is National 30308, hope that helps, and Happy New Year!!!
Moderated by  Dusty53
