| | | Forums66 Topics128,066 Posts1,055,871 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 11 New Guy | | New Guy Joined: Aug 2010 Posts: 11 | I was trying to figure out what rear axle was in my one ton dually. I first thought it was an HO72 but the bolt pattern is different than a HO52 that I have and I thought they were the same I might be wrong though. Also there is no thrust pad that I thought all the Eaton HOs had. Thanks Pics of axle | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy spectra, that is a Timken rear axle. Are there any numbers on the tag? Does it take the same wheels as the front axle? I'll look in my books and see what I can find. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy spectra, can you tell us your series designation? A 57 250 series with a V8, lists a Timken B100 as standard equipment, could that be it? | | | | | Joined: Aug 2010 Posts: 11 New Guy | | New Guy Joined: Aug 2010 Posts: 11 | 3B thanks for the replies it is a V8 250 series the numbers on the axle are B101HX1 and 176497 it has a 5.14 ratio. and yes both front and rear are the same eight bolt. Do you know if parts are available like seals and such? Thanks
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy spectra, according to my Bower/BCA catalog the wheel seal is National 2081, and the pinion seal is National 30308, hope that helps, and Happy New Year!!! | | |
