1 members (Hotrod Lincoln), 75 guests, and 3 robots.
Topics128,090
Posts1,056,376
Members48,442
#707693 12/31/2010 6:24 PM
...So I was stripping down my engine for a trip to the machine shop. I want to have the shop put in a new oil pump with the rebuild. I got down to taking off the oil pump and found two circular headed bolts that go through the block and into the oil pump housing. the threads on the housing side are peened off.
It seems to me the only way to remove is to drill them out, as the heads are perfectly round, and don't take a socket.
Can anyone confirm or deny?
1958 Chevy Apache Fleetside/235/3 sp
Pictures at http://www.facebook.com/album.php?aid=317454&id=855355703&l=0a0f773195
I remember being fooled by that too. Th oil pump is retained by a single bolt with a tapered end and lock nut. Look for it near the crankshaft where the pump slides into the block and if you back it off the pump will slip out. No drilling or grinding required.
You Tube
Confirm that they don't take a socket.
Deny that you drill them out.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=646392
-Tom
1950 Chevy 3100 w/ 1956 235
http://www.chevytrucks.org/tech/engine1.htm You need to look at this, it tells you how to do it correctly. I just got this info in an earlier post today. I'm taking mine apart real soon. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
I was told after I had removed those two round headed bolts on a 216 that a mistake was made on my part because those two bolts are critical to the correct positioning of the oil pump in the block and that is why they are rounded because they are not to be removed. Luckily for me,when I replaced those 2 bolts and the oil pump, all seemed to work ok. When rebuilding my 235, I left them alone.
Drew
Ahhhh yes, I see it now. Glad I asked!
